简介
Guide for the replacement of the middle frame that includes Power Button, Audio Jack and Microphones
你所需要的
Remove the battery cover by grabbing the notch under the bottom speakers and lifting.
Use Plastic opening tools to separate the LCD from the Main body
Use a plastic tool to carefully switch up the LCD ribbon holder
Detach the LCD from the main board
With a plastic tool, untie the system board by detaching the ribbons attached to it
The battery ribbon is on the bottom right
Once all Ribbons untied, gently wiggle the system board out of the frame
4等其他人完成本指南。
