跳转到主内容
BlackBerry Z30 Logic board Replacement
你所需要的
  1. BlackBerry Z30 Logic board Replacement, Battery cover: 步骤 1 中的图像 1,1
    • Remove the battery cover by grabbing the notch under the bottom speakers and lifting.
  2. BlackBerry Z30 Logic board Replacement, Remove SIM and Media Card: 步骤 2 中的图像 1,1
    • Remove the SIM card and the Media SD card by pushing on them.
  3. BlackBerry Z30 Logic board Replacement, Unscrewing the LCD panel: 步骤 3 中的图像 1,3 BlackBerry Z30 Logic board Replacement, Unscrewing the LCD panel: 步骤 3 中的图像 2,3 BlackBerry Z30 Logic board Replacement, Unscrewing the LCD panel: 步骤 3 中的图像 3,3
    • Locate and unscrew all 10 T5 screws around the back cover
  4. BlackBerry Z30 Logic board Replacement, Separate the LCD from the Frame: 步骤 4 中的图像 1,2 BlackBerry Z30 Logic board Replacement, Separate the LCD from the Frame: 步骤 4 中的图像 2,2
    • Use Plastic opening tools to separate the LCD from the Main body
    • Do NOT remove the screen yet, it is attached with a very fragile ribbon to the main board.
    • Start on the same side of the Audio Jack
  5. BlackBerry Z30 Logic board Replacement, Remove the LCD: 步骤 5 中的图像 1,2 BlackBerry Z30 Logic board Replacement, Remove the LCD: 步骤 5 中的图像 2,2
    • Use a plastic tool to carefully switch up the LCD ribbon holder
    • Detach the LCD from the main board
    • When installing the new LCD, make sure the ribbon is inserted to the white line.
  6. BlackBerry Z30 Logic board Replacement, LCD Panel removal: 步骤 6 中的图像 1,1
    • You can now detach the LCD Panel from the main frame.
  7. BlackBerry Z30 Logic board Replacement, Untie the System board: 步骤 7 中的图像 1,1
    • With a plastic tool, untie the system board by detaching the ribbons attached to it
    • The battery ribbon is on the bottom right
    • Be gentle when detaching these Ribbons as they are very easy to tear and damage.
  8. BlackBerry Z30 Logic board Replacement, Untie the System board Part 2: 步骤 8 中的图像 1,1
    • Be gentle as any other system board ribbons, they are very easy to damage
  9. BlackBerry Z30 Logic board Replacement, Untie the system board Part 3: 步骤 9 中的图像 1,1
    • Power Button /Audio Jack
    • Flash
    • Rear Facing Camera
  10. BlackBerry Z30 Logic board Replacement, System board removal: 步骤 10 中的图像 1,1
    • Once all Ribbons untied, gently wiggle the system board out of the frame
    • Do not pull hard as there might be a ribbon on the way
结论
4等其他人完成本指南。
Hans
于10/20/14注册
1,920 声望
创作了6篇指南
团队
Mero IT Services Mero IT Services 的会员
Business
1 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 4,016
