跳转到主内容
修复你的物品
维修的权力
商店
简介
This guide will allow you to safely replace the LCD panel of your BlackBerry Z30 unit.
  1. Remove the battery cover by grabbing the notch under the bottom speakers and lifting.
    • Remove the battery cover by grabbing the notch under the bottom speakers and lifting.
  2. Remove the SIM card and the Media SD card by pushing on them.
    • Remove the SIM card and the Media SD card by pushing on them.
  3. Locate and unscrew all 10 T5 screws around the back cover Locate and unscrew all 10 T5 screws around the back cover Locate and unscrew all 10 T5 screws around the back cover
    • Locate and unscrew all 10 T5 screws around the back cover
  4. Use Plastic opening tools to separate the LCD from the Main body Do NOT remove the screen yet, it is attached with a very fragile ribbon to the main board.
    • Use Plastic opening tools to separate the LCD from the Main body
    • Do NOT remove the screen yet, it is attached with a very fragile ribbon to the main board.
    • Start on the same side of the Audio Jack
  5. Use a plastic tool to carefully switch up the LCD ribbon holder Detach the LCD from the main board
    • Use a plastic tool to carefully switch up the LCD ribbon holder
    • Detach the LCD from the main board
    • When installing the new LCD, make sure the ribbon is inserted to the white line.
  6. You can now detach the LCD Panel from the main frame.
    • You can now detach the LCD Panel from the main frame.
结论
10等其他人完成本指南。
Hans
于2014年10月20日注册
1,759 信誉积分
创作了6篇指南
团队
Mero IT Services Mero IT Services 的会员
Business
1 名成员
创作了6篇指南
This YouTube video by ItsmeJC also helped a lot.
https://www.youtube.com/watch?v=yISRs3lW...
I had difficulties when trying to re-insert and re-lock the ribbon in place, but it turned out that I overlooked and missed the fact that the ribbon should go under the ribbon holder, not between it and the "fixing switch". Otherwise, the procedure was a snap.
Syafiq Saidan - 回复
After screen replacement I'm having proximity sensor issues. screen is responsive and everything works good but its flashing on and off. disconnecting the proximity sensor fixes the issue but it's also the same connection as lock button so not an option. reinstalling original screen works as normal, new screen is original manufacture and has the same foam gaskets and uv filters as original around the prox sensor...
any thoughts?
Andrew - 回复
Hi Andrew,
Beware, some sellers claims their screens are original but they are not. The few times the issue you have discribed occured to me where when the LCD unit was defective. Please arrange an exchange with your seller if you can. The fact that when you put back your shattered screen and it works is the proof that your new unit is defective.
Good luck.
Hans -
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 12,493
