跳转到主内容
BlackBerry World Edition 8830 Trackball Replacement
你所需要的
  1. BlackBerry World Edition 8830 Trackball Replacement, Trackball: 步骤 1 中的图像 1,3 BlackBerry World Edition 8830 Trackball Replacement, Trackball: 步骤 1 中的图像 2,3 BlackBerry World Edition 8830 Trackball Replacement, Trackball: 步骤 1 中的图像 3,3
    • Make sure the phone is powered off before removing the trackball.
    • Gently use the Small Flathead Screwdriver or plastic opening tool to go under the chrome ring surrounding the trackball.
    • Pry the chrome ring upwards with the tool until it begins to lift up.
    • Once it begins to lift up, gently remove the chrome ring from around the trackball.
    • When re-assembling the phone, be sure to orient the chrome ring so that the missing tab is at the top.
  2. BlackBerry World Edition 8830 Trackball Replacement: 步骤 2 中的图像 1,2 BlackBerry World Edition 8830 Trackball Replacement: 步骤 2 中的图像 2,2
    • After removing the chrome ring, slowly lift up the remaining piece with tweezers.
    • Slowly remove the small plastic bottom using the Plastic Opener tool. Be careful not to bend the metal frame when removing the bottom plastic piece.
    • Using your hands, remove the white plastic piece, revealing the small metal frame, the scroll wheels, and the trackball.
  3. BlackBerry World Edition 8830 Trackball Replacement: 步骤 3 中的图像 1,1
    • Slowly remove the trackball, being cautious not to scratch the ball or the scroll wheels.
    • Using a soft cloth, carefully remove any dust around the scroll wheels or the trackball itself.
    • While the trackball is removed, you may clean the sensor in the hole where the trackball is usually located.
结论
tbace
于04/18/12注册
28 声望
创作了2篇指南
团队
Cal Poly, Team 17-27, Amido Spring 2012 Cal Poly, Team 17-27, Amido Spring 2012 的会员
CPSU-AMIDO-S12S17G27
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 1,033
