跳转到主内容
BlackBerry World Edition 8830 Keyboard Replacement
你所需要的
  1. BlackBerry World Edition 8830 Keyboard Replacement, Battery: 步骤 1 中的图像 1,3 BlackBerry World Edition 8830 Keyboard Replacement, Battery: 步骤 1 中的图像 2,3 BlackBerry World Edition 8830 Keyboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Before beginning this installation, make sure phone is powered off .
    • Turn phone over to the backside.
    • Press down on the lower portion of the back cover.
    • Slide the lower portion down to remove the cover and reveal the battery.
  2. BlackBerry World Edition 8830 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Remove the battery from the phone.
  3. BlackBerry World Edition 8830 Keyboard Replacement, Front and Back Casing: 步骤 3 中的图像 1,2 BlackBerry World Edition 8830 Keyboard Replacement, Front and Back Casing: 步骤 3 中的图像 2,2
    • Once the battery is removed, remove the four 9.2 mm screws with the T4 Torx Screwdriver.
  4. BlackBerry World Edition 8830 Keyboard Replacement: 步骤 4 中的图像 1,3 BlackBerry World Edition 8830 Keyboard Replacement: 步骤 4 中的图像 2,3 BlackBerry World Edition 8830 Keyboard Replacement: 步骤 4 中的图像 3,3
    • Remove side panels with the Plastic Opening Tool by sliding it along the edge of the panel until you can pry it off with the tool.
  5. BlackBerry World Edition 8830 Keyboard Replacement: 步骤 5 中的图像 1,2 BlackBerry World Edition 8830 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Remove the back casing using the Plastic Opening Tool
    • Once the back casing is removed the top two buttons are likely to pop out.
  6. BlackBerry World Edition 8830 Keyboard Replacement: 步骤 6 中的图像 1,3 BlackBerry World Edition 8830 Keyboard Replacement: 步骤 6 中的图像 2,3 BlackBerry World Edition 8830 Keyboard Replacement: 步骤 6 中的图像 3,3
    • Locate the two 9.2mm screws on the upper inside casing
    • Remove them using the T4 Torx Screwdriver
    • Slide off the front casing once the screws are removed.
    • Trackball will fall out once the casing is removed.
  7. BlackBerry World Edition 8830 Keyboard Replacement, Keyboard: 步骤 7 中的图像 1,3 BlackBerry World Edition 8830 Keyboard Replacement, Keyboard: 步骤 7 中的图像 2,3 BlackBerry World Edition 8830 Keyboard Replacement, Keyboard: 步骤 7 中的图像 3,3
    • Remove the keyboard from the front casing.
结论
团队
Cal Poly, Team 17-27, Amido Spring 2012 Cal Poly, Team 17-27, Amido Spring 2012 的会员
CPSU-AMIDO-S12S17G27
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 14
总计 536
