跳转到主内容
BlackBerry Torch 9850 Battery Replacement
  1. BlackBerry Torch 9850 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Power off the device.
    • Press and hold down the power/end button on the phone until phone powers off and the screen goes black.
  2. BlackBerry Torch 9850 Battery Replacement: 步骤 2 中的图像 1,2 BlackBerry Torch 9850 Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the plastic cover that would normally be on the back of the phone.
    • Press down on the release button, which is located on the bottom of the back side of the phone.
    • Lift up on the plastic covering and remove.
  3. BlackBerry Torch 9850 Battery Replacement: 步骤 3 中的图像 1,3 BlackBerry Torch 9850 Battery Replacement: 步骤 3 中的图像 2,3 BlackBerry Torch 9850 Battery Replacement: 步骤 3 中的图像 3,3
    • Remove the battery.
    • Once the plastic covering is removed, you can remove the battery.
    • Use your fingers or a plastic spudger to pop the bottom of the battery out of its place by pushing and lifting.
    • Once the bottom of the battery has ejected, you can easily remove the whole battery from the phone with your hands.
  4. BlackBerry Torch 9850 Battery Replacement: 步骤 4 中的图像 1,2 BlackBerry Torch 9850 Battery Replacement: 步骤 4 中的图像 2,2
    • Inserting a new battery.
    • Align the plus and minus signs at the top of the battery compartment with the plus and minus signs at the top of the battery.
    • Push battery into place.
    • Replace the plastic cover by snapping into place.
结论
另外一个人完成了本指南。
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 20
总计 587
