当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Now use a safe pry tool, and go along the edges of the phone to release the clips to open the housing. There are a total of 6 clips, 3 on each side.
There is a small cap connection that connects the antenna to the logic board as pictured.
Once you have worked you way all the way around the device with the safe pry tool you can now separate the two pieces of the housing.
*Be sure to remove the antenna cable in the top portion of the housing. You will need to reattach this when you repair the phone*
Put your broken assembly to the side, and now install your new one following the past steps in reverse.
Before ordering your new part, check the number on your existing LCD, it will either be V.014 or V.024. (Shown in blue)
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
