跳转到主内容
BlackBerry Storm LCD/Digitizer Replacement
你所需要的
  1. BlackBerry Storm LCD/Digitizer Replacement, LCD/Digitizer: 步骤 1 中的图像 1,1
    • Turn your Blackberry Storm 9500 onto its back side, and remove the battery door & battery.
  2. BlackBerry Storm LCD/Digitizer Replacement: 步骤 2 中的图像 1,1
    • Remove the 2 screws (T6) under the battery compartment they are located as shown in red.
  3. BlackBerry Storm LCD/Digitizer Replacement: 步骤 3 中的图像 1,1
    • Turn the Blackberry Storm 9500 around and pry off the microphone cover at the top using a safe pry tool.
  4. BlackBerry Storm LCD/Digitizer Replacement: 步骤 4 中的图像 1,1
    • Remove the two screws(T6) as shown.
  5. BlackBerry Storm LCD/Digitizer Replacement: 步骤 5 中的图像 1,1
    • Flip it back over to the back of the phone, and remove the plastic lens on top of the camera & flash. This is held in place by some adhesive, so use a safe pry tool to remove as shown.
  6. BlackBerry Storm LCD/Digitizer Replacement: 步骤 6 中的图像 1,1
    • Once the plastic piece is removed, unscrew the two torx screws underneath it.
  7. BlackBerry Storm LCD/Digitizer Replacement: 步骤 7 中的图像 1,3 BlackBerry Storm LCD/Digitizer Replacement: 步骤 7 中的图像 2,3 BlackBerry Storm LCD/Digitizer Replacement: 步骤 7 中的图像 3,3
    • Now use a safe pry tool, and go along the edges of the phone to release the clips to open the housing. There are a total of 6 clips, 3 on each side.
    • There is a small cap connection that connects the antenna to the logic board as pictured.
  8. BlackBerry Storm LCD/Digitizer Replacement: 步骤 8 中的图像 1,1
    • Once you have worked you way all the way around the device with the safe pry tool you can now separate the two pieces of the housing.
    • *Be sure to remove the antenna cable in the top portion of the housing. You will need to reattach this when you repair the phone*
  9. BlackBerry Storm LCD/Digitizer Replacement: 步骤 9 中的图像 1,1
    • Now remove the logic board & LCD assembly from the rear housing. Be gentle, and do not use excessive force.
  10. BlackBerry Storm LCD/Digitizer Replacement: 步骤 10 中的图像 1,2 BlackBerry Storm LCD/Digitizer Replacement: 步骤 10 中的图像 2,2
    • Flip the logicboard around so that it is sitting on top of the screen, now remove the two ribbon cables for the LCD & Digitizer.
  11. BlackBerry Storm LCD/Digitizer Replacement: 步骤 11 中的图像 1,1
    • Put your broken assembly to the side, and now install your new one following the past steps in reverse.
    • Before ordering your new part, check the number on your existing LCD, it will either be V.014 or V.024. (Shown in blue)
结论
13等其他人完成本指南。
Josh Forester
于11/28/10注册
2,497 声望
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 16
总计 21,108
