当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Have a cracked screen? Need to replace your speaker? Etc? Well just follow these steps.
Turn your Storm where the battery door is facing up.
Remove the battery door.
Remove the battery.
Remove the two hex screws as shown by the SIM card slot.
Remove the plastic piece that covers the camera & flash on the back . This is held in with some tape so use a safe pry tool.
Remove the two hex screws underneath it.
Turn the phone over and remove the plastic cover under the buttons as shown.
Remove the 2 screws underneath.
Go around your device with the plastic pry tool, there a 3 clips on each side of the housing.
There is a connection for the antenna from the front to mid housing. Remove it with a pry tool if it does not come off by itself.
You now have 3 pieces. The rear, mid , & front housing.
To remove the screen gently pry up this ribbon cable with a pry tool.
To remove the main board from the mid housing disconnect the ribbon cable as pictured.
Now follow in reverse order for reassembly!
取消:我没有完成这个指南。
6等其他人完成本指南。
与3其他贡献者
于11/28/10注册
2,497 声望
创作了10篇指南
徽章: 31
+ 28更多徽章
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 9,550
