跳转到主内容
BlackBerry PlayBook Speaker Replacement
你所需要的
  1. BlackBerry PlayBook Speaker Replacement, Remove Back Panel: 步骤 1 中的图像 1,2 BlackBerry PlayBook Speaker Replacement, Remove Back Panel: 步骤 1 中的图像 2,2
    • Use a plastic opening tool to pry the back panel off by inserting it in between the front and back panel.
    • There are clips that need to be released on all four sides of the device.
    • When replacing the back cover insert the bottom side first ( usb and hdmi ports stick out about 2mm ) inserting them into the covers openings will allow for easier reassembly
  2. BlackBerry PlayBook Speaker Replacement, Unscrew Left Speaker: 步骤 2 中的图像 1,1
    • Remove 1.55x.33mm Phillips screw from the metal frame.
    • Remove 1.5x4.25mm Phillips screw from speaker bar.
  3. BlackBerry PlayBook Speaker Replacement, Remove the Left Speaker Stickers: 步骤 3 中的图像 1,2 BlackBerry PlayBook Speaker Replacement, Remove the Left Speaker Stickers: 步骤 3 中的图像 2,2
    • Peel off the stickers holding the left speaker in place with a tweezer or by using your fingers
  4. BlackBerry PlayBook Speaker Replacement, Remove Left Speaker: 步骤 4 中的图像 1,2 BlackBerry PlayBook Speaker Replacement, Remove Left Speaker: 步骤 4 中的图像 2,2
    • Slide the left speaker bar out from its metal bracket.
  5. BlackBerry PlayBook Speaker Replacement, Unscrew Right Speaker: 步骤 5 中的图像 1,1
    • Remove both 1.5x4.25mm Phillips screws from the right speaker bar by using the Phillips Screwdriver.
  6. BlackBerry PlayBook Speaker Replacement, Remove Right Speaker: 步骤 6 中的图像 1,2 BlackBerry PlayBook Speaker Replacement, Remove Right Speaker: 步骤 6 中的图像 2,2
    • Lift the right speaker bar to remove it.
结论
另外一个人完成了本指南。
Nathan
于10/12/14注册
652 声望
创作了4篇指南
团队
Cal Poly, Team 14-27, Maness Fall 2014 Cal Poly, Team 14-27, Maness Fall 2014 的会员
CPSU-MANESS-F14S14G27
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 958
