跳转到主内容
BlackBerry Pearl 8100 Keyboard Replacement
你所需要的
  1. BlackBerry Pearl 8100 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Before working on the phone, be sure that the device is turned off.
    • Begin by removing the back panel; this can be done by pressing the silver button on the backside of the Blackberry 8100, while simultaneously sliding the back panel off.
    • Remove the battery located directly below back panel.
  2. BlackBerry Pearl 8100 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Using a 1.5 mm Hex screwdriver, remove the two screws that hold the two panels together.
  3. BlackBerry Pearl 8100 Keyboard Replacement: 步骤 4 中的图像 1,2 BlackBerry Pearl 8100 Keyboard Replacement: 步骤 4 中的图像 2,2
    • Using the spudger, pry off the small portion of the casing located at the bottom of the phone.
  4. BlackBerry Pearl 8100 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Using the spudger, pry off the side casings one at a time by wedging it between the inner casing and the sides.
  5. BlackBerry Pearl 8100 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Using a 1.5mm Hex screwdriver, unscrew the two screws, located on the front of the phone, that connect the back and front panels.
  6. BlackBerry Pearl 8100 Keyboard Replacement: 步骤 7 中的图像 1,2 BlackBerry Pearl 8100 Keyboard Replacement: 步骤 7 中的图像 2,2
    • Using the spudger, pry off the back body panel by wedging the spudger in between the front and back panels on the side face. Remove the back body panel.
  7. BlackBerry Pearl 8100 Keyboard Replacement: 步骤 8 中的图像 1,1
    • Separate the logic board from the front panel.
  8. BlackBerry Pearl 8100 Keyboard Replacement: 步骤 9 中的图像 1,2 BlackBerry Pearl 8100 Keyboard Replacement: 步骤 9 中的图像 2,2
    • Gently remove the keyboard from front casing. It should snap out of place.
结论
另外一个人完成了本指南。
Robert Cronin
于04/08/10注册
544 声望
创作了6篇指南
团队
Cal Poly, Team 34-57, Forte Spring 2010 Cal Poly, Team 34-57, Forte Spring 2010 的会员
CPSU-FORTE-S10S34G57
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 20
总计 5,441
