跳转到主内容
BlackBerry Pearl 8100 Disassembly
你所需要的
  1. BlackBerry Pearl 8100 Disassembly, Rear Cover: 步骤 1 中的图像 1,1
    • Push the button indicated by the yellow marker to remove the rear cover.
    • Remove the battery (not pictured).
  2. BlackBerry Pearl 8100 Disassembly, Screws underneath the rear cover: 步骤 2 中的图像 1,1
    • Use a T6 Torx screwdriver to remove the two screws indicated by the yellow markers.
  3. BlackBerry Pearl 8100 Disassembly, Bottom Cover: 步骤 3 中的图像 1,2 BlackBerry Pearl 8100 Disassembly, Bottom Cover: 步骤 3 中的图像 2,2
    • Use the plastic opening tool to loosen the bottom cover, and then remove the bottom cover from the cellphone.
  4. BlackBerry Pearl 8100 Disassembly, Side Cover: 步骤 4 中的图像 1,2 BlackBerry Pearl 8100 Disassembly, Side Cover: 步骤 4 中的图像 2,2
    • Use the plastic opening tool to remove the side covers.
    • The side covers are attached to the cell phone with small plastic snaps. These snaps can be bent or broken easily.
  5. BlackBerry Pearl 8100 Disassembly, More screws: 步骤 5 中的图像 1,1
    • With the bottom and side covers removed, the two screws indicated by yellow markers will be visible.
    • Use the T6 Torx screwdriver to remove the screws.
  6. BlackBerry Pearl 8100 Disassembly, Frame: 步骤 6 中的图像 1,2 BlackBerry Pearl 8100 Disassembly, Frame: 步骤 6 中的图像 2,2
    • With the screws removed, the frame can be detached.
  7. BlackBerry Pearl 8100 Disassembly, Logic Board: 步骤 7 中的图像 1,2 BlackBerry Pearl 8100 Disassembly, Logic Board: 步骤 7 中的图像 2,2
    • Use the plastic opening tool to separate the motherboard from the front cover.
    • While removing the motherboard, the button that opens the rear cover may come loose along with a small spring. Do not lose these.
  8. BlackBerry Pearl 8100 Disassembly, Keypad and Trackball: 步骤 8 中的图像 1,2 BlackBerry Pearl 8100 Disassembly, Keypad and Trackball: 步骤 8 中的图像 2,2
    • Separate the keypad (first picture) and trackball (second picture) from the front cover.
    • Lift the piece of plastic that overlays the trackball (second picture). The trackball should then come loose.
    • Keep the trackball intact. The trackball has extremely small magnetic bolts underneath that are difficult to reassemble.
  9. BlackBerry Pearl 8100 Disassembly, Complete: 步骤 9 中的图像 1,1
    • These are all the parts of the BlackBerry Pearl 8100 completely disassembled. From left to right, the parts are as follows: rear cover, front cover, motherboard, side covers, trackball, keypad, bottom cover, and frame.
结论
另外一个人完成了本指南。
Justin
于10/06/14注册
150 声望
创作了2篇指南
团队
Aristotle Aristotle 的会员
Community
5 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 684
