跳转到主内容
BlackBerry KeyONE partial Disassembly
你所需要的
  1. BlackBerry KeyONE partial Disassembly, Remove top cover: 步骤 1 中的图像 1,1
    • Carefully remove the top plastic cover. It is held in place by adhesive.
  2. BlackBerry KeyONE partial Disassembly, Remove top frame: 步骤 2 中的图像 1,2 BlackBerry KeyONE partial Disassembly, Remove top frame: 步骤 2 中的图像 2,2
    • Remove the two Philipps #0 screws that hold in place the top of the phone frame and slide it off.
  3. BlackBerry KeyONE partial Disassembly, Remove back cover: 步骤 3 中的图像 1,1
    • Remove the back cover. It mostly just clips off, but has some adhesive in the lower area.
  4. BlackBerry KeyONE partial Disassembly, Disconnect Battery: 步骤 4 中的图像 1,2 BlackBerry KeyONE partial Disassembly, Disconnect Battery: 步骤 4 中的图像 2,2
    • Remove the two Philipps #0 screws securing the battery connector and unplug the later.
  5. BlackBerry KeyONE partial Disassembly: 步骤 5 中的图像 1,1
    • Remove the 6 Philipps #0 screws securing the lower cover and remove it.
    • Remove the three Philipps #0 screws holding down the bar that secures the two main lego-style plugs and remove it.
  6. BlackBerry KeyONE partial Disassembly, Remove top cover: 步骤 6 中的图像 1,1
    • Remove the three Philipps #0 screws securing the upper cover and remove it.
  7. BlackBerry KeyONE partial Disassembly: 步骤 7 中的图像 1,1
    • Unplug the remaining ribbon cables
    • Remove the last three Philipps #0 screws securing the Motherbard.
    • Now you should be able to replace most components.
    • The screen is held in place from the front by adhesive (or not, in the earlier versions), its cable slides trough the phone to the PCB - It's the large connector in the middle.
    • The battery is glued to the frame firmly. There are three pultabs located underneath the motherboard.
    • Don't forget to remove the sim-tray if you're removing the motherboard.
结论
14等其他人完成本指南。
raven
于09/02/15注册
1,080 声望
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 61
总计 9,469
