跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This will guide you on how to dissassemble your blackberry curve to replace the broken speaker with a new speaker.
  1. Pry off the back and separate it from the front of the phone case. You will see the battery once the cover is removed.
    • Pry off the back and separate it from the front of the phone case. You will see the battery once the cover is removed.
  2. On both sides of the battery, there is a lighter grey half-circle. This is the best place to use your fingers to gently lift the battery free of the housing. On both sides of the battery, there is a lighter grey half-circle. This is the best place to use your fingers to gently lift the battery free of the housing.
    • On both sides of the battery, there is a lighter grey half-circle. This is the best place to use your fingers to gently lift the battery free of the housing.
  3. Using a small plastic opening tool, remove the lower rear cover.
    • Using a small plastic opening tool, remove the lower rear cover.
  4. Remove six screws from the midframe of the device.
    • Remove six screws from the midframe of the device.
  5. Manta 螺丝刀工具包
    日常维修的112个替换头
    Upgrade Your Toolbox
    Manta 螺丝刀工具包
  6. Remove the midframe from the phone.
    • Remove the midframe from the phone.
  7. Gently pry the back the plastic tabs that secure the motherboard to the case. Slowly work your way around the case until the tabs until the motherboard comes free.
    • Gently pry the back the plastic tabs that secure the motherboard to the case.
    • Slowly work your way around the case until the tabs until the motherboard comes free.
    • Remove the motherboard.
    • The keypad and navigation ball may become loose and fall away from the motherboard.
  8. Carefully detach the antenna from the two clips on the side of the motherboard. Carefully disconnect the antenna from the motherboard.
    • Carefully detach the antenna from the two clips on the side of the motherboard.
    • Carefully disconnect the antenna from the motherboard.
  9. Carefully disconnect the ribbon cable on the bottom right of the motherboard.
    • Carefully disconnect the ribbon cable on the bottom right of the motherboard.
  10. Remove the screen so that it does not get damaged. Remove the screen so that it does not get damaged.
    • Remove the screen so that it does not get damaged.
  11. Lift the up motherboard from the bottom edge to reveal to ribbon cables. Carefully disconnect the two ribbon cables connecting the motherboard and display.
    • Lift the up motherboard from the bottom edge to reveal to ribbon cables.
    • Carefully disconnect the two ribbon cables connecting the motherboard and display.
  12. Replace the entire center piece of the case to replace the speaker.
    • Replace the entire center piece of the case to replace the speaker.
结论
2等其他人完成本指南。
Johnny Tran
于2011年09月10日注册
473 信誉积分
创作了4篇指南
团队
Cuesta, Team 1-3, Zipperian Fall 2011 Cuesta, Team 1-3, Zipperian Fall 2011 的会员
CUESTA-ZIPPERIAN-F11S1G3
3 名成员
创作了8篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 7,675
