跳转到主内容
BlackBerry Curve 8900 Screen Replacement
你所需要的
  1. BlackBerry Curve 8900 Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Open the rear panel to expose the battery and the chassis assembly. Remove the battery.
  2. BlackBerry Curve 8900 Screen Replacement: 步骤 2 中的图像 1,1
    • Use a small, non-marring plastic opening tool to remove the lower-rear cover. (Credit cards and guitar picks work great.)
  3. BlackBerry Curve 8900 Screen Replacement: 步骤 3 中的图像 1,1
    • Use a T6 Torx screwdriver to loosen and remove the six screws from the chassis as shown.
    • Flip the phone over to the front and remove the plastic bezel.
  4. BlackBerry Curve 8900 Screen Replacement: 步骤 4 中的图像 1,1
    • Remove the midframe from the back of the phone, which should now be free after removing the screws. The green motherboard should now be exposed.
  5. BlackBerry Curve 8900 Screen Replacement: 步骤 5 中的图像 1,1
    • Remove the front-cover by carefully prying the side release tabs, located on the side of the phone.
  6. BlackBerry Curve 8900 Screen Replacement: 步骤 6 中的图像 1,3 BlackBerry Curve 8900 Screen Replacement: 步骤 6 中的图像 2,3 BlackBerry Curve 8900 Screen Replacement: 步骤 6 中的图像 3,3
    • Gently pry the side release tabs to lift the flexing keypad from the frame.
    • The navigation ball may come loose at this point. Set it aside with the keypad for reassembly.
  7. BlackBerry Curve 8900 Screen Replacement: 步骤 7 中的图像 1,1
    • Gently lift the motherboard.
    • Locate the screen's ribbon cable underneath the motherboard, and detach it from the phone.
  8. BlackBerry Curve 8900 Screen Replacement: 步骤 8 中的图像 1,2 BlackBerry Curve 8900 Screen Replacement: 步骤 8 中的图像 2,2
    • Carefully pry at the sides of the screen until the display assembly is free. Remove the display from the motherboard unit.
结论
4等其他人完成本指南。
Renae Bishop
于09/07/11注册
68 声望
创作了4篇指南
团队
Cuesta, Team 1-3, Zipperian Fall 2011 Cuesta, Team 1-3, Zipperian Fall 2011 的会员
CUESTA-ZIPPERIAN-F11S1G3
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 6
总计 4,320
