当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Remove the six screws from the mid-frame of the device, using the T6 Torx Screwdriver.
Set the screws aside once they've been removed.
Gently pull back the plastic tabs that secure the motherboard to the case.
Slowly pull the tabs, working your way around the case, until they are lifted and the motherboard is free.
Remove the motherboard.
The keypad and navigation ball may become loose and fall off the motherboard.
Locate the chip underneath the screen.
Gently remove the screen, without applying too much pressure, taking care not to damage it.
Lift up the motherboard from the bottom edge to reveal the ribbon cables.
Carefully disconnect the two ribbon cables connecting the motherboard to the display on either side.
Remove the motherboard and place off to the side.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
