跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
BlackBerry Curve 8900 Motherboard Replacement
你所需要的
  1. BlackBerry Curve 8900 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the back cover of the phone.
    • The battery will now be visible.
  2. BlackBerry Curve 8900 Motherboard Replacement: 步骤 2 中的图像 1,2 BlackBerry Curve 8900 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Pinch the battery at the grey semi-circles on the top left and top right corners of the battery using your fingers and remove it from the device.
  3. BlackBerry Curve 8900 Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Using a small plastic opening tool, remove the lower rear cover.
  4. BlackBerry Curve 8900 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove six screws from the midframe of the device.
  5. BlackBerry Curve 8900 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the midframe from the phone.
  6. BlackBerry Curve 8900 Motherboard Replacement: 步骤 6 中的图像 1,2 BlackBerry Curve 8900 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Gently pry the back the plastic tabs that secure the motherboard to the case.
    • Slowly work your way around the case until the tabs until the motherboard comes free.
    • Remove the motherboard.
    • The keypad and navigation ball may become loose and fall away from the motherboard.
  7. BlackBerry Curve 8900 Motherboard Replacement: 步骤 7 中的图像 1,2 BlackBerry Curve 8900 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Carefully detach the antenna from the two clips on the side of the motherboard.
    • Carefully disconnect the antenna from the motherboard.
  8. BlackBerry Curve 8900 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Carefully disconnect the ribbon cable on the bottom right of the motherboard.
  9. BlackBerry Curve 8900 Motherboard Replacement: 步骤 9 中的图像 1,2 BlackBerry Curve 8900 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Remove the screen so that it does not get damaged.
  10. BlackBerry Curve 8900 Motherboard Replacement: 步骤 10 中的图像 1,2 BlackBerry Curve 8900 Motherboard Replacement: 步骤 10 中的图像 2,2
    • Lift the up motherboard from the bottom edge to reveal to ribbon cables.
    • Carefully disconnect the two ribbon cables connecting the motherboard and display.
结论
3等其他人完成本指南。
Johnny Tran
于09/10/11注册
473 声望
创作了4篇指南
团队
Cuesta, Team 1-3, Zipperian Fall 2011 Cuesta, Team 1-3, Zipperian Fall 2011 的会员
CUESTA-ZIPPERIAN-F11S1G3
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 4,081
