跳转到主内容
BlackBerry Curve 8900 Microphone Replacement
你所需要的
  1. BlackBerry Curve 8900 Microphone Replacement, Microphone: 步骤 1 中的图像 1,1
    • Press and slide the battery cover from the back of the device with your fingers.
    • Remove the battery by pulling it out.
    • The battery is shown outside of the device on the right side of the photograph, "BlackBerry D-X18."
  2. BlackBerry Curve 8900 Microphone Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    iFixit Opening Tool
    $1.99
    购买
    • Using the iFixit Opening Tool, remove the lower rear cover.
  3. BlackBerry Curve 8900 Microphone Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    T6 Torx Screwdriver
    $9.99
    购买
  4. BlackBerry Curve 8900 Microphone Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    iFixit Opening Tool
    $1.99
    购买
  5. BlackBerry Curve 8900 Microphone Replacement: 步骤 5 中的图像 1,2 BlackBerry Curve 8900 Microphone Replacement: 步骤 5 中的图像 2,2
    • Work your way around the case, slowly, prying the back of the plastic tabs until the motherboard comes free.
  6. BlackBerry Curve 8900 Microphone Replacement: 步骤 6 中的图像 1,1
    • With your fingers, carefully remove the screen so as not to damage it.
  7. BlackBerry Curve 8900 Microphone Replacement: 步骤 7 中的图像 1,2 BlackBerry Curve 8900 Microphone Replacement: 步骤 7 中的图像 2,2
    • With your fingers, carefully unhook the antenna cable in all three locations.
  8. BlackBerry Curve 8900 Microphone Replacement: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    Spudger
    $3.99
    购买
    • Detach the ribbon cable on the front of the motherboard using the Spudger tool.
  9. BlackBerry Curve 8900 Microphone Replacement: 步骤 9 中的图像 1,1
    • Detach the motherboard from both ribbon connections.
    • The ribbon connections are indicated by red circles on the photograph.
    • The ribbon connections are indicated by orange rectangles on the photograph.
  10. BlackBerry Curve 8900 Microphone Replacement: 步骤 10 中的图像 1,2 BlackBerry Curve 8900 Microphone Replacement: 步骤 10 中的图像 2,2
    • Replace the entire motherboard to replace the microphone.
结论
另外一个人完成了本指南。
Johnny Tran
于09/10/11注册
473 声望
创作了4篇指南
团队
Cuesta, Team 1-3, Zipperian Fall 2011 Cuesta, Team 1-3, Zipperian Fall 2011 的会员
CUESTA-ZIPPERIAN-F11S1G3
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 4,440
