当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Gently pry back the plastic tabs that secure the motherboard to the case.
Slowly work your way around the case prying the tabs until the motherboard comes free.
Remove the motherboard.
The keypad and navigation ball may become loose and fall away from the motherboard.
Lift the keypad from the motherboard.
When replacing the keypad, be sure that the navigation ball is in its original position.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
