跳转到主内容
BlackBerry Curve 8900 Case Replacement
你所需要的
  1. BlackBerry Curve 8900 Case Replacement, Removing the Case: 步骤 1 中的图像 1,2 BlackBerry Curve 8900 Case Replacement, Removing the Case: 步骤 1 中的图像 2,2
    • Remove the rear cover from the phone.
    • Remove the battery.
  2. BlackBerry Curve 8900 Case Replacement, Remove the Rear Cover: 步骤 2 中的图像 1,1
    • Using a small plastic opening tool, remove the lower rear cover.
  3. BlackBerry Curve 8900 Case Replacement, Unscrew the Midframe: 步骤 3 中的图像 1,1
    • Remove the six screws from the midframe of the device.
    • Be careful not to damage the screws while removing them.
  4. BlackBerry Curve 8900 Case Replacement, Remove the Midframe: 步骤 4 中的图像 1,1
    • Remove the midframe from the phone.
  5. BlackBerry Curve 8900 Case Replacement, Remove the Motherboard: 步骤 5 中的图像 1,2 BlackBerry Curve 8900 Case Replacement, Remove the Motherboard: 步骤 5 中的图像 2,2
    • Gently pry the back the plastic tabs that secure the motherboard to the case.
    • Slowly work your way around the case with the tabs until the motherboard comes free.
    • Remove the motherboard.
    • The keypad and navigation ball may become loose and fall away from the motherboard.
结论
Use the new case and reassemble the phone by doing the instructions in reverse order.
2等其他人完成本指南。
Renae Bishop
于09/07/11注册
68 声望
创作了4篇指南
团队
Cuesta, Team 1-3, Zipperian Fall 2011 Cuesta, Team 1-3, Zipperian Fall 2011 的会员
CUESTA-ZIPPERIAN-F11S1G3
3 名成员
创作了8篇指南
一条评论
Excellent, please suggest me how can I get the replacement original case shipped to Gaborone, Botswana. I also need two screws shown at the top of the cell at step 3
d.arm1965 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 3,353
