本指南有最近更改,您可查看未经巡查的最新版本。
简介
Few tools are required to do this.
A small plastic pry tool or even a fingernail is sufficient. Working area surface should be clean and dry with adequate lighting.
Immediately wash hands after handling the battery and completing the process. Discard the dead battery properly.
Pry off the back and separate it from the front of the phone case. You will see the battery once the cover is removed.
Set aside the old battery, then replace it with the new battery. It should easily fit into place. Then, you can replace the backing of phone, pressing gently to secure it down.
另外一个人完成了本指南。
