跳转到主内容
BlackBerry Curve 8900 Battery Replacement
  1. BlackBerry Curve 8900 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the back cover of the phone.
    • The battery will now be visible.
  2. BlackBerry Curve 8900 Battery Replacement: 步骤 2 中的图像 1,2 BlackBerry Curve 8900 Battery Replacement: 步骤 2 中的图像 2,2
    • Pinch the battery at the grey semi-circles on the top left and top right corners of the battery using your fingers and remove it from the device.
结论
Set aside the old battery, then replace it with the new battery. It should easily fit into place. Then, you can replace the backing of phone, pressing gently to secure it down.
另外一个人完成了本指南。
Renae Bishop
于09/07/11注册
68 声望
创作了4篇指南
团队
Cuesta, Team 1-3, Zipperian Fall 2011 Cuesta, Team 1-3, Zipperian Fall 2011 的会员
CUESTA-ZIPPERIAN-F11S1G3
3 名成员
创作了8篇指南
一条评论
were do i get one
Hooman Afshari - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 9
总计 3,251
