跳转到主内容
BlackBerry Curve 8530 Motherboard Replacement
你所需要的
  1. BlackBerry Curve 8530 Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 BlackBerry Curve 8530 Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Place the phone on a flat surface with the screen facing down.
    • Remove the plastic backplate by pulling up on the bottom of the cover.
  2. BlackBerry Curve 8530 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by pulling up from the top of the battery.
  3. BlackBerry Curve 8530 Motherboard Replacement, Keypad: 步骤 3 中的图像 1,2 BlackBerry Curve 8530 Motherboard Replacement, Keypad: 步骤 3 中的图像 2,2
    • Remove the two screws midway up the phone on the left and right sides using a T6 Torx Screwdriver.
    • Warning: One screw will have warranty tape covering the screw. Removing this screw will likely void the phones warranty.
  4. BlackBerry Curve 8530 Motherboard Replacement: 步骤 4 中的图像 1,2 BlackBerry Curve 8530 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Flip the phone over so the keyboard faces up.
    • Insert a plastic spudger into the screen where speaker resides.
    • I recommend going from the side. There are two layers to the cover. You need to make sure you get underneath the bottom layer if you plan on reusing this cover.
    • Gently lift up plastic screen cover until screen cover separates from screen.
    • Continue until screen cover is completely removed.
  5. BlackBerry Curve 8530 Motherboard Replacement: 步骤 5 中的图像 1,3 BlackBerry Curve 8530 Motherboard Replacement: 步骤 5 中的图像 2,3 BlackBerry Curve 8530 Motherboard Replacement: 步骤 5 中的图像 3,3
    • Insert the spudger into the top of the plastic siding on the front of the phone and lift up until the siding lifts up.
    • Slide the tool around the entire perimeter of the phone until the plastic siding is completely removed.
  6. BlackBerry Curve 8530 Motherboard Replacement: 步骤 6 中的图像 1,2 BlackBerry Curve 8530 Motherboard Replacement: 步骤 6 中的图像 2,2
    • The keyboard should slide off of the phone now that the plastic siding has been removed.
  7. BlackBerry Curve 8530 Motherboard Replacement, Screen: 步骤 7 中的图像 1,3 BlackBerry Curve 8530 Motherboard Replacement, Screen: 步骤 7 中的图像 2,3 BlackBerry Curve 8530 Motherboard Replacement, Screen: 步骤 7 中的图像 3,3
    • To detach the screen, there are two screws at the top of the phone to be removed. Use the T6 Torx Screwdriver to remove the screws.
    • There is a gold ribbon on the top left of the phone. Lift up this ribbon gently until it is detached from the phone.
    • Note: When reassembling, the ribbon should be reattached before replacing the top screws.
  8. BlackBerry Curve 8530 Motherboard Replacement: 步骤 8 中的图像 1,3 BlackBerry Curve 8530 Motherboard Replacement: 步骤 8 中的图像 2,3 BlackBerry Curve 8530 Motherboard Replacement: 步骤 8 中的图像 3,3
    • There are two clips on each side of the phone. Insert a plastic spudger between the clips and the screen.
    • Use pressure to unlatch the screen from the clips.
    • Now that these clips have been undone, the screen should lift up easily.
  9. BlackBerry Curve 8530 Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,2 BlackBerry Curve 8530 Motherboard Replacement, Motherboard: 步骤 9 中的图像 2,2
    • Now there are four screws that need to be removed. They are located at the bottom of the phone and can also be removed using a T6 Torx Screwdriver.
  10. BlackBerry Curve 8530 Motherboard Replacement: 步骤 10 中的图像 1,3 BlackBerry Curve 8530 Motherboard Replacement: 步骤 10 中的图像 2,3 BlackBerry Curve 8530 Motherboard Replacement: 步骤 10 中的图像 3,3
    • Now the motherboard will lift up out of the plastic backing of the phone.
终点
10等其他人完成本指南。
Cory Davis
于04/19/11注册
503 声望
创作了3篇指南
团队
Cal Poly, Team 15-13, Regan Spring 2011 Cal Poly, Team 15-13, Regan Spring 2011 的会员
CPSU-REGAN-S11S15G13
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 10,750
