跳转到主内容
BlackBerry Curve 8530 Keypad Replacement
你所需要的
  1. BlackBerry Curve 8530 Keypad Replacement, Battery: 步骤 1 中的图像 1,2 BlackBerry Curve 8530 Keypad Replacement, Battery: 步骤 1 中的图像 2,2
    • Place the phone on a flat surface with the screen facing down.
    • Remove the plastic backplate by pulling up on the bottom of the cover.
  2. BlackBerry Curve 8530 Keypad Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by pulling up from the top of the battery.
  3. BlackBerry Curve 8530 Keypad Replacement, Keypad: 步骤 3 中的图像 1,2 BlackBerry Curve 8530 Keypad Replacement, Keypad: 步骤 3 中的图像 2,2
    • Remove the two screws midway up the phone on the left and right sides using a T6 Torx Screwdriver.
    • Warning: One screw will have warranty tape covering the screw. Removing this screw will likely void the phones warranty.
  4. BlackBerry Curve 8530 Keypad Replacement: 步骤 4 中的图像 1,2 BlackBerry Curve 8530 Keypad Replacement: 步骤 4 中的图像 2,2
    • Flip the phone over so the keyboard faces up.
    • Insert a plastic spudger into the screen where speaker resides.
    • I recommend going from the side. There are two layers to the cover. You need to make sure you get underneath the bottom layer if you plan on reusing this cover.
    • Gently lift up plastic screen cover until screen cover separates from screen.
    • Continue until screen cover is completely removed.
  5. BlackBerry Curve 8530 Keypad Replacement: 步骤 5 中的图像 1,3 BlackBerry Curve 8530 Keypad Replacement: 步骤 5 中的图像 2,3 BlackBerry Curve 8530 Keypad Replacement: 步骤 5 中的图像 3,3
    • Insert the spudger into the top of the plastic siding on the front of the phone and lift up until the siding lifts up.
    • Slide the tool around the entire perimeter of the phone until the plastic siding is completely removed.
  6. BlackBerry Curve 8530 Keypad Replacement: 步骤 6 中的图像 1,2 BlackBerry Curve 8530 Keypad Replacement: 步骤 6 中的图像 2,2
    • The keyboard should slide off of the phone now that the plastic siding has been removed.
结论
To reassemble the device, follow the instructions in reverse order.
4等其他人完成本指南。
Cory Davis
于04/19/11注册
503 声望
创作了3篇指南
团队
Cal Poly, Team 15-13, Regan Spring 2011 Cal Poly, Team 15-13, Regan Spring 2011 的会员
CPSU-REGAN-S11S15G13
3 名成员
创作了5篇指南
一条评论
This is a handy technique I will use it when next time I fix my phone and if you get time do visit us we fix these type of problems in India, Kolkata here is our site link https://techyuga.com/kolkata/
Ankita - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 6
总计 6,398
