跳转到主内容
BlackBerry Curve 8520 Motherboard Replacement
你所需要的
  1. BlackBerry Curve 8520 Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,2 BlackBerry Curve 8520 Motherboard Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Insert a plastic opening tool into the small notch on the rear cover of the phone.
    • Pry the rear cover up from the phone.
  2. BlackBerry Curve 8520 Motherboard Replacement, Battery: 步骤 2 中的图像 1,2 BlackBerry Curve 8520 Motherboard Replacement, Battery: 步骤 2 中的图像 2,2
    • Locate the slit between the top of the battery and the casing.
    • Gently apply pressure on the top of the battery to trigger the spring release.
  3. BlackBerry Curve 8520 Motherboard Replacement, Keyboard Cover: 步骤 3 中的图像 1,2 BlackBerry Curve 8520 Motherboard Replacement, Keyboard Cover: 步骤 3 中的图像 2,2
    • Remove the two Torx T6 screws to the left and right of the battery.
  4. BlackBerry Curve 8520 Motherboard Replacement: 步骤 4 中的图像 1,2 BlackBerry Curve 8520 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Using hairdryer or heat gun, warm the front panel to soften the adhesive beneath.
    • Starting from one side, use a plastic opening tool to pry up the screen cover.
    • Work carefully to avoid bending the screen cover.
    • Once one side is loose, gently peel up the entire cover.
  5. BlackBerry Curve 8520 Motherboard Replacement: 步骤 5 中的图像 1,3 BlackBerry Curve 8520 Motherboard Replacement: 步骤 5 中的图像 2,3 BlackBerry Curve 8520 Motherboard Replacement: 步骤 5 中的图像 3,3
    • Insert the plastic opening tool in the seam along the side of the device.
    • Slide the tool along the length of the seam, applying moderate force with the plastic opening tool.
    • Carefully remove the faceplate.
  6. BlackBerry Curve 8520 Motherboard Replacement: 步骤 6 中的图像 1,3 BlackBerry Curve 8520 Motherboard Replacement: 步骤 6 中的图像 2,3 BlackBerry Curve 8520 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Remove four T6 Torx screws from the front of the phone.
    • Using tweezers, remove the keyboard buttons from the phone.
  7. BlackBerry Curve 8520 Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,2 BlackBerry Curve 8520 Motherboard Replacement, Motherboard: 步骤 7 中的图像 2,2
    • Remove the two T6 Torx screws securing the small plastic bracket at the bottom of the phone.
    • Remove the four T6 Torx screws from the corners of the keyboard.
  8. BlackBerry Curve 8520 Motherboard Replacement: 步骤 8 中的图像 1,2 BlackBerry Curve 8520 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Using a plastic opening tool, gently pry the motherboard assembly from the device's frame.
结论
32等其他人完成本指南。
Matt
于04/07/11注册
1,722 声望
创作了5篇指南
团队
Cal Poly, Team 9-62, Walters Spring 2011 Cal Poly, Team 9-62, Walters Spring 2011 的会员
CPSU-WALTERS-S11S9G62
5 名成员
创作了5篇指南
一条评论
hi sir can u provide me the dead 8520 cuvre mobile phone
hunkerbhullar - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 36,779
