简介
Use this guide to replace the keyboard cover of your BlackBerry Curve 8520.
  1. Insert a plastic opening tool into the small notch on the rear cover of the phone. Pry the rear cover up from the phone.
    • Insert a plastic opening tool into the small notch on the rear cover of the phone.
    • Pry the rear cover up from the phone.
  2. Locate the slit between the top of the battery and the casing. Gently apply pressure on the top of the battery to trigger the spring release.
    • Locate the slit between the top of the battery and the casing.
    • Gently apply pressure on the top of the battery to trigger the spring release.
  3. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. Remove the two Torx T6 screws to the left and right of the battery. Remove the two Torx T6 screws to the left and right of the battery.
    • Remove the two Torx T6 screws to the left and right of the battery.
  5. Using hairdryer or heat gun, warm the front panel to soften the adhesive beneath. Starting from one side, use a plastic opening tool to pry up the screen cover.
    • Using hairdryer or heat gun, warm the front panel to soften the adhesive beneath.
    • Starting from one side, use a plastic opening tool to pry up the screen cover.
      • Work carefully to avoid bending the screen cover.
    • Once one side is loose, gently peel up the entire cover.
  6. Insert the plastic opening tool in the seam along the side of the device. Slide the tool along the length of the seam, applying moderate force with the plastic opening tool. Carefully remove the faceplate.
    • Insert the plastic opening tool in the seam along the side of the device.
    • Slide the tool along the length of the seam, applying moderate force with the plastic opening tool.
    • Carefully remove the faceplate.
  7. Remove four T6 Torx screws from the front of the phone. Using tweezers, remove the keyboard buttons from the phone. Using tweezers, remove the keyboard buttons from the phone.
    • Remove four T6 Torx screws from the front of the phone.
    • Using tweezers, remove the keyboard buttons from the phone.
结论
27等其他人完成本指南。
Matt
于2011年04月07日注册
1,710 信誉积分
创作了5篇指南
团队
Cal Poly, Team 9-62, Walters Spring 2011 Cal Poly, Team 9-62, Walters Spring 2011 的会员
CPSU-WALTERS-S11S9G62
5 名成员
创作了5篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 8
过去的30天: 26
总计 34,677
