跳转到主内容
BlackBerry Curve 8310 Lens Replacement
你所需要的
  1. BlackBerry Curve 8310 Lens Replacement, Battery: 步骤 1 中的图像 1,1
    • Press down on the battery release button and slide the back cover up with your thumb.
  2. BlackBerry Curve 8310 Lens Replacement: 步骤 2 中的图像 1,1
    • Pry from the top of the battery to pull it out.
  3. BlackBerry Curve 8310 Lens Replacement, Lens: 步骤 3 中的图像 1,1
    • Slide the metal sim card cover to the unlock position.
    • Remove the sim card.
    • The arrows on the sim card enclosure indicate the lock and unlock positions.
  4. BlackBerry Curve 8310 Lens Replacement: 步骤 4 中的图像 1,1
    • Remove the two T5 Torx screws circled at the top of the phone.
    • The T5 Torx screws may be covered by a white sticker.
  5. BlackBerry Curve 8310 Lens Replacement: 步骤 5 中的图像 1,1
    • Remove the red cover at the bottom of the phone.
    • You may have to work a spudger underneath to release the plastic clips.
  6. BlackBerry Curve 8310 Lens Replacement: 步骤 6 中的图像 1,3 BlackBerry Curve 8310 Lens Replacement: 步骤 6 中的图像 2,3 BlackBerry Curve 8310 Lens Replacement: 步骤 6 中的图像 3,3
    • Be careful not to damage the front cover's plastic clips while trying to separate it from the phone.
    • Use a spudger to pry the front cover away from the side panels.
    • Work the spudger around the entire phone until the front cover is free.
结论
Sean Willis
于01/26/12注册
229 声望
创作了5篇指南
团队
Cal Poly, Team 10-32, Amido Winter 2012 Cal Poly, Team 10-32, Amido Winter 2012 的会员
CPSU-AMIDO-W12S10G32
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 6
总计 980
