当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Press down on the battery release button and slide the back cover up with your thumb.
Pry from the top of the battery to pull it out.
Slide the metal sim card cover to the unlock position.
Remove the sim card.
The arrows on the sim card enclosure indicate the lock and unlock positions.
Remove the two T5 Torx screws circled at the top of the phone.
The T5 Torx screws may be covered by a white sticker.
Remove the red cover at the bottom of the phone.
You may have to work a spudger underneath to release the plastic clips.
Be careful not to damage the front cover's plastic clips while trying to separate it from the phone.
Use a spudger to pry the front cover away from the side panels.
Work the spudger around the entire phone until the front cover is free.
Remove the keyboard.
取消:我没有完成这个指南。
2等其他人完成本指南。
与5其他贡献者
于01/20/12注册
91 声望
创作了2篇指南
徽章: 7
+ 4更多徽章
CPSU-AMIDO-W12S10G32
4 名成员
创作了8篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,944
