跳转到主内容
BlackBerry 8820 Motherboard Replacement
你所需要的
  1. BlackBerry 8820 Motherboard Replacement, Disassembling BlackBerry 8820 Outer Casing: 步骤 1 中的图像 1,1
    • Remove the battery cover by applying pressure and sliding down the silver square on the back of the phone.
  2. BlackBerry 8820 Motherboard Replacement: 步骤 2 中的图像 1,2 BlackBerry 8820 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the battery by prying under it with your finger or the plastic opening tool.
    • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
  3. BlackBerry 8820 Motherboard Replacement: 步骤 3 中的图像 1,2 BlackBerry 8820 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Use a nylon spudger to carefully remove the two side bars of plastic.
  4. BlackBerry 8820 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Use a nylon spudger to carefully pry the back casing off.
    • There are two small clamps on each edge that need to be unhooked before the casing will come off.
  5. BlackBerry 8820 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Pry off the front casing.
    • Be aware of sensors and other sensitive areas of the newly exposed electronics.
  6. BlackBerry 8820 Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,2 BlackBerry 8820 Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,2
    • Remove the bottom casing clip, it will easily unsnap when pulled
  7. BlackBerry 8820 Motherboard Replacement: 步骤 7 中的图像 1,2 BlackBerry 8820 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Unhook both sides of the white wire from the motherboard using the plastic opening tool from before
  8. BlackBerry 8820 Motherboard Replacement: 步骤 8 中的图像 1,2 BlackBerry 8820 Motherboard Replacement: 步骤 8 中的图像 2,2
    • At the top of the phone, locate the gloss SATA cable strap connecting the LCD screen to the phone.
    • Using the prying tool, unattach this cable by levering under the connector
    • When removing the ribbon cable handle with care; it is prone to breaking
  9. BlackBerry 8820 Motherboard Replacement: 步骤 9 中的图像 1,2 BlackBerry 8820 Motherboard Replacement: 步骤 9 中的图像 2,2
    • WARNING: Be sure to have disconnected the SATA cable strap prior to attempting this.
    • Using the prying tool, lever up the old screen as shown.
  10. BlackBerry 8820 Motherboard Replacement: 步骤 10 中的图像 1,3 BlackBerry 8820 Motherboard Replacement: 步骤 10 中的图像 2,3 BlackBerry 8820 Motherboard Replacement: 步骤 10 中的图像 3,3
    • There will be two small clips on each side of the motherboard. Using the plastic opening tool unhook each clip one at a time
    • Once all four clips are unhooked you should be able to pull the motherboard from the casing using your hands.
    • After you remove the old motherboard, you can then replace it with a new one.
结论
3等其他人完成本指南。
ryan
于04/12/13注册
44 声望
创作了5篇指南
团队
Cal Poly, Team 13-64, Johann Spring 2013 Cal Poly, Team 13-64, Johann Spring 2013 的会员
CPSU-JOHANN-S13S13G64
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 910
