跳转到主内容
BlackBerry 8820 LCD Screen Replacement
你所需要的
  1. BlackBerry 8820 LCD Screen Replacement, Outer Casing: 步骤 1 中的图像 1,1
    • Remove the battery cover by applying pressure and sliding the silver square on the back of the phone downwards.
  2. BlackBerry 8820 LCD Screen Replacement: 步骤 2 中的图像 1,2 BlackBerry 8820 LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Remove the battery by prying under it with your finger or a plastic opening tool.
    • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
  3. BlackBerry 8820 LCD Screen Replacement: 步骤 3 中的图像 1,2 BlackBerry 8820 LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Carefully remove the two plastic side bars using a nylon spudger.
  4. BlackBerry 8820 LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Carefully pry the back casing off with a nylon spudger.
    • There are two small clamps on each edge that need to be unhooked before the casing can come off.
  5. BlackBerry 8820 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Pry off the front casing.
    • Be cautious of sensors and other sensitive areas of the newly exposed electronics.
  6. BlackBerry 8820 LCD Screen Replacement, LCD Screen: 步骤 6 中的图像 1,1
    • After disassembling the outer casing, the phone should be stripped as shown.
  7. BlackBerry 8820 LCD Screen Replacement: 步骤 7 中的图像 1,2 BlackBerry 8820 LCD Screen Replacement: 步骤 7 中的图像 2,2
    • At the top of the phone, locate the gloss SATA cable strap connecting the LCD screen to the phone.
    • Using the prying tool, disconnect the SATA cable by levering under the connector.
  8. BlackBerry 8820 LCD Screen Replacement: 步骤 8 中的图像 1,2 BlackBerry 8820 LCD Screen Replacement: 步骤 8 中的图像 2,2
    • Using a spudger, pry up the old screen as shown.
    • Be sure that the SATA cable is disconnected prior to attempting this.
  9. BlackBerry 8820 LCD Screen Replacement: 步骤 9 中的图像 1,2 BlackBerry 8820 LCD Screen Replacement: 步骤 9 中的图像 2,2
    • Insert the new LCD screen.
    • Attach the cable to the connector located at the top of the phone.
结论
ryan
于04/12/13注册
44 声望
创作了5篇指南
团队
Cal Poly, Team 13-64, Johann Spring 2013 Cal Poly, Team 13-64, Johann Spring 2013 的会员
CPSU-JOHANN-S13S13G64
4 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 8
总计 782
