跳转到主内容
BlackBerry 8703e Battery Replacement
你所需要的
  1. BlackBerry 8703e Battery Replacement, Battery: 步骤 1 中的图像 1,2 BlackBerry 8703e Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Position your phone like the first image so that the highlighted button is on your left.
    • Slide the battery cover to the left while pressing the button with one hand and applying pressure on the center of the phone with your other hand.
    • Remove the cover completely and set it aside.
  2. BlackBerry 8703e Battery Replacement: 步骤 2 中的图像 1,1
    • Position your phone like the image to the left, then locate the rectangular battery in the middle of the phone.
    • Locate the notch on the top right of the battery compartment.
    • Slide your fingernail or the flat end of a Spudger in the notch, then lift upwards on the top of the battery to remove it from the phone.
    • Set the battery aside and out of the way.
结论
团队
Cal Poly, Team 11-3, Forte Winter 2010 Cal Poly, Team 11-3, Forte Winter 2010 的会员
CPSU-FORTE-W10S11G3
5 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 3,422
