跳转到主内容
BlackBerry 8700c Replacing Logic Board Replacement
你所需要的
  1. BlackBerry 8700c Replacing Logic Board Replacement, Replacing Logic Board: 步骤 1 中的图像 1,2 BlackBerry 8700c Replacing Logic Board Replacement, Replacing Logic Board: 步骤 1 中的图像 2,2
    • Remove the back cover by pushing down on the button and sliding the cover towards the bottom of the phone.
    • Set the cover aside. The battery will now be exposed.
  2. BlackBerry 8700c Replacing Logic Board Replacement: 步骤 2 中的图像 1,2 BlackBerry 8700c Replacing Logic Board Replacement: 步骤 2 中的图像 2,2
    • Remove the battery by pulling back on the notch on top edge of the battery.
    • Set the battery aside.
  3. BlackBerry 8700c Replacing Logic Board Replacement: 步骤 3 中的图像 1,1
    • Unscrew and remove all four T6 Torx screws.
  4. BlackBerry 8700c Replacing Logic Board Replacement: 步骤 4 中的图像 1,2 BlackBerry 8700c Replacing Logic Board Replacement: 步骤 4 中的图像 2,2
    • Pull the back cover of the phone off and set it aside.
  5. BlackBerry 8700c Replacing Logic Board Replacement: 步骤 5 中的图像 1,2 BlackBerry 8700c Replacing Logic Board Replacement: 步骤 5 中的图像 2,2
    • Unscrew and remove all 4 T6 Torx screws.
  6. BlackBerry 8700c Replacing Logic Board Replacement: 步骤 6 中的图像 1,3 BlackBerry 8700c Replacing Logic Board Replacement: 步骤 6 中的图像 2,3 BlackBerry 8700c Replacing Logic Board Replacement: 步骤 6 中的图像 3,3
    • Lift and remove inner back cover and set aside.
    • A small side piece may fall away but is simple to reattach.
    • Remove logic board by gently lifting it off of the front cover of the phone.
    • New logic board can now simply be set in place.
结论
arlebrun
于12/02/09注册
1 声望
撰写一个指南
团队
Cal Poly, Team 18-4, Maness Fall 2009 Cal Poly, Team 18-4, Maness Fall 2009 的会员
CPSU-MANESS-F09S18G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 3,228
