跳转到主内容
BlackBerry 7510 Vibration Motor Replacement
你所需要的
  1. BlackBerry 7510 Vibration Motor Replacement, Back Face of Phone: 步骤 1 中的图像 1,1
    • Remove the battery cover and battery before continuing.
    • Remove the six T6 Torx screws on the back of the phone.
    • Make sure to keep the screws somewhere that they will not get lost.
  2. BlackBerry 7510 Vibration Motor Replacement: 步骤 2 中的图像 1,1
    • Using your finger nail or a spudger, carefully pry up the back cover.
    • Begin in one spot and slowly circle around the device as you pry up all of the back cover.
  3. BlackBerry 7510 Vibration Motor Replacement: 步骤 3 中的图像 1,1
    • Lift off the back cover.
  4. BlackBerry 7510 Vibration Motor Replacement: 步骤 4 中的图像 1,1
    • Remove the two T6 screws.
  5. BlackBerry 7510 Vibration Motor Replacement: 步骤 5 中的图像 1,2 BlackBerry 7510 Vibration Motor Replacement: 步骤 5 中的图像 2,2
    • Remove the daughterboard.
    • Remove the exposed vibration motor.
  6. BlackBerry 7510 Vibration Motor Replacement, Vibration Motor: 步骤 6 中的图像 1,1
    • Replace with new vibration motor.
结论
Neil Johnson
于01/24/10注册
12 声望
创作了6篇指南
团队
Cal Poly, Team 14-44, Regan Winter 2010 Cal Poly, Team 14-44, Regan Winter 2010 的会员
CPSU-REGAN-W10S14G44
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 4,561
