跳转到主内容
BlackBerry 7510 Logic Board Replacement
你所需要的
  1. BlackBerry 7510 Logic Board Replacement, Back Face of Phone: 步骤 1 中的图像 1,1
    • Remove the battery cover and battery before continuing.
    • Remove the six T6 Torx screws on the back of the phone.
    • Make sure to keep the screws somewhere that they will not get lost.
  2. BlackBerry 7510 Logic Board Replacement: 步骤 2 中的图像 1,1
    • Using your finger nail or a spudger, carefully pry up the back cover.
    • Begin in one spot and slowly circle around the device as you pry up all of the back cover.
  3. BlackBerry 7510 Logic Board Replacement: 步骤 3 中的图像 1,1
    • Lift off the back cover.
  4. BlackBerry 7510 Logic Board Replacement: 步骤 4 中的图像 1,1
    • Remove the two T6 screws.
  5. BlackBerry 7510 Logic Board Replacement: 步骤 5 中的图像 1,2 BlackBerry 7510 Logic Board Replacement: 步骤 5 中的图像 2,2
    • Remove the daughterboard.
    • Remove the exposed vibration motor.
  6. BlackBerry 7510 Logic Board Replacement, Logic Board: 步骤 6 中的图像 1,1
    • Using the T6 Torx screwdriver, remove the top screw.
  7. BlackBerry 7510 Logic Board Replacement: 步骤 7 中的图像 1,1
    • Using your spudger, carefully pry off back plate.
    • Use the same technique as with the plastic back cover. Circle around the back plate until all of it is pried up.
  8. BlackBerry 7510 Logic Board Replacement: 步骤 8 中的图像 1,1
    • Remove the front cover and keypad.
  9. BlackBerry 7510 Logic Board Replacement: 步骤 9 中的图像 1,1
    • Remove one T6 Torx screw in the front bottom right of the board.
  10. BlackBerry 7510 Logic Board Replacement: 步骤 10 中的图像 1,2 BlackBerry 7510 Logic Board Replacement: 步骤 10 中的图像 2,2
    • Carefully pry the screen from the board with your spudger.
    • After prying it up, remove the screen from the board.
  11. BlackBerry 7510 Logic Board Replacement: 步骤 11 中的图像 1,2 BlackBerry 7510 Logic Board Replacement: 步骤 11 中的图像 2,2
    • Unscrew center T6 Torx screw in the center of the logic board.
    • Remove the logic board from the phone.
    • Replace with new logic board.
结论
Neil Johnson
于01/24/10注册
12 声望
创作了6篇指南
团队
Cal Poly, Team 14-44, Regan Winter 2010 Cal Poly, Team 14-44, Regan Winter 2010 的会员
CPSU-REGAN-W10S14G44
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 1,868
