简介
Use this guide to replace the motherboard on your RIM BlackBerry 7290.
你所需要的
Apply pressure to the lock button on the back of the device.
Slide the battery cover down towards the bottom of the device, revealing the battery compartment.
Locate the four screws along the perimeter of the back casing.
Remove the four top screws using a T-6 torx screwdriver.
On the front side of the internals, locate the the three screws that are highlighted in red.
Carefully remove screws from the internals, using a T6 torx screwdriver
2等其他人完成本指南。
