当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Apply pressure to the lock button on the back of the device.
Slide the battery cover down towards the bottom of the device, revealing the battery compartment.
Locate the four screws along the perimeter of the back casing.
Remove the four top screws using a T-6 torx screwdriver.
The top four screws are .413 inches.
Locate two screws within the lower edge of the inner compartment.
Remove the two bottom screws using a T-6 torx screwdriver.
The bottom two screws are .2 inches in length.
The second picture displays the device after the six screws have been removed.
Remove the back casing from the phone by lifting the unhooked portion, then slide the casing towards the top of the device.
Make sure all clips holding the case together are unhooked, so no damage is caused to the case.
Locate on the backside of the phone, a screw towards the top of the device.
Using a T-6 screwdriver, remove the screw.
After the screw has been removed, carefully lift the side button brace to reveal the side button.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
