简介
The logic board is the computational center of the phone. The logic board also contains the USB port, headphone jack, and the track-wheel. This guide will demonstrate how to remove the logic board from the bracket once the phone is opened.
你所需要的
With your thumb press down on the locking- button on the back of the BlackBerry 7280.
Slide the battery cover off the device.
Hold the device with both hands.
Lift the SIM card holder using your thumb and index finger.
Remove the SIM card from the device.
Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside.
Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket. Set aside the screw and the bracket.
Use the plastic opening tool to pry at the edge of the screen near the track-wheel.
