跳转到主内容
BlackBerry 7280 LCD Screen and Speaker Replacement
你所需要的
  1. BlackBerry 7280 LCD Screen and Speaker Replacement, Battery: 步骤 1 中的图像 1,3 BlackBerry 7280 LCD Screen and Speaker Replacement, Battery: 步骤 1 中的图像 2,3 BlackBerry 7280 LCD Screen and Speaker Replacement, Battery: 步骤 1 中的图像 3,3
    • With your thumb press down on the locking- button on the back of the BlackBerry 7280.
    • Slide the battery cover off the device.
  2. BlackBerry 7280 LCD Screen and Speaker Replacement: 步骤 2 中的图像 1,2 BlackBerry 7280 LCD Screen and Speaker Replacement: 步骤 2 中的图像 2,2
    • Remove the lithium-ion battery from the back of the device using your index finger.
  3. BlackBerry 7280 LCD Screen and Speaker Replacement, SIM Card: 步骤 3 中的图像 1,3 BlackBerry 7280 LCD Screen and Speaker Replacement, SIM Card: 步骤 3 中的图像 2,3 BlackBerry 7280 LCD Screen and Speaker Replacement, SIM Card: 步骤 3 中的图像 3,3
    • Hold the device with both hands.
    • Lift the SIM card holder using your thumb and index finger.
    • Remove the SIM card from the device.
  4. BlackBerry 7280 LCD Screen and Speaker Replacement, Back Case: 步骤 4 中的图像 1,2 BlackBerry 7280 LCD Screen and Speaker Replacement, Back Case: 步骤 4 中的图像 2,2
    • Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside.
    • The SIM card has been removed here to prevent damage to the card. This is recommended, but not not required.
  5. BlackBerry 7280 LCD Screen and Speaker Replacement: 步骤 5 中的图像 1,2 BlackBerry 7280 LCD Screen and Speaker Replacement: 步骤 5 中的图像 2,2
    • Use the plastic opening tool to pry the back case away from the front case.
  6. BlackBerry 7280 LCD Screen and Speaker Replacement, Front Case: 步骤 6 中的图像 1,2 BlackBerry 7280 LCD Screen and Speaker Replacement, Front Case: 步骤 6 中的图像 2,2
    • Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket. Set aside the screw and the bracket.
  7. BlackBerry 7280 LCD Screen and Speaker Replacement: 步骤 7 中的图像 1,2 BlackBerry 7280 LCD Screen and Speaker Replacement: 步骤 7 中的图像 2,2
    • Remove the front plastic case from the metal bracket.
  8. BlackBerry 7280 LCD Screen and Speaker Replacement, LCD Screen and Speaker: 步骤 8 中的图像 1,2 BlackBerry 7280 LCD Screen and Speaker Replacement, LCD Screen and Speaker: 步骤 8 中的图像 2,2
    • Use the plastic opening tool to pry at the edge of the screen near the track-wheel.
结论
Sarah Waddill
于03/11/13注册
10 声望
创作了5篇指南
团队
Clemson, Team 12-2, Benson Spring 2013 Clemson, Team 12-2, Benson Spring 2013 的会员
CLEM-BENSON-S13S12G2
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 356
