简介
The keypad is the external part of the keyboard consisting of the rubber buttons. This keypad rests in the front case.
工具
配件
没有特定配件。
With your thumb press down on the locking- button on the back of the BlackBerry 7280.
Slide the battery cover off the device.
Hold the device with both hands.
Lift the SIM card holder using your thumb and index finger.
Remove the SIM card from the device.
Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside.
Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket. Set aside the screw and the bracket.
The keypad sits in the keyboard slots on the front cover. Simply peel the keyboard off and replace.
另外一个人完成了本指南。
