跳转到主内容
加入维修社区 - 创建账户
BlackBerry 7130e Disassembly
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. BlackBerry 7130e Disassembly, BlackBerry 7130e Disassembly: 步骤 1 中的图像 1,1
    • Using the T6 Torx screwdriver, remove the bottom two screws on the back of the phone.
  2. BlackBerry 7130e Disassembly: 步骤 2 中的图像 1,1
    • Remove speaker phone cover by unsecuring the two latches on the edge close to top of the phone with the plastic opening tool.
  3. BlackBerry 7130e Disassembly: 步骤 3 中的图像 1,1
    • Detach the speaker phone cover by pulling up on the bottom of the speaker phone cover.
    • As you detach the speaker phone cover you will notice a sticky glue sealing the rubber gasket from the cover to the speaker mesh. This is normal and will correctly reset the first few times the pieces are separated.
  4. BlackBerry 7130e Disassembly: 步骤 4 中的图像 1,1
    • Remove top two screws with T6 Torx screw driver, from the back of phone.
  5. BlackBerry 7130e Disassembly: 步骤 5 中的图像 1,1
    • Turn the phone sideways and unlatch the hinge on one side of the phone by pushing inwards and twisting to the side with the plastic opening tool.
  6. BlackBerry 7130e Disassembly: 步骤 6 中的图像 1,2 BlackBerry 7130e Disassembly: 步骤 6 中的图像 2,2
    • You should now be able to easily separate the phone into two pieces.
    • The battery prong may fall out when the separation occurs, just don't loose it!
结论
Sean Tiernan
于01/20/10注册
5 声望
创作了5篇指南
团队
Cal Poly, Team 3-16, Maness Winter 2010 Cal Poly, Team 3-16, Maness Winter 2010 的会员
CPSU-MANESS-W10S3G16
4 名成员
创作了11篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 9
总计 1,035
