简介
This guide explains how to replace the motherboard for your BlackBerry 7100g.
你所需要的
Turn over your BalckBerry 7100g so that the back cover is facing up.
Locate the battery cover release button near the bottom of the back panel.
Locate the silver strip near the top of your BlackBerry.
Use a plastic opening tool to pry off the edge of the silver lining.
Slide the tool along the length of the silver strip to completely remove it.
Turn over the motherboard so that the speaker is facing up.
Locate and unscrew the four (4) screws near the bottom of the motherboard, using a T6 screwdriver.
Turn the "guts" over so the speaker is facing up.
Separate the battery housing from the motherboard.
Locate the ribbon connector below the bottom of the screen.
Use a spudger to flip up the connector.
另外一个人完成了本指南。
