跳转到主内容
BlackBerry 7100g Housing Replacement
你所需要的
  1. BlackBerry 7100g Housing Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn over your BalckBerry 7100g so that the back cover is facing up.
    • Locate the battery cover release button near the bottom of the back panel.
  2. BlackBerry 7100g Housing Replacement: 步骤 2 中的图像 1,3 BlackBerry 7100g Housing Replacement: 步骤 2 中的图像 2,3 BlackBerry 7100g Housing Replacement: 步骤 2 中的图像 3,3
    • Push down on the release button with one thumb.
    • Slide the battery cover off with the other thumb.
  3. BlackBerry 7100g Housing Replacement: 步骤 3 中的图像 1,1
    • Remove the battery from the battery housing by flipping up the top of the battery.
  4. BlackBerry 7100g Housing Replacement, Housing: 步骤 4 中的图像 1,3 BlackBerry 7100g Housing Replacement, Housing: 步骤 4 中的图像 2,3 BlackBerry 7100g Housing Replacement, Housing: 步骤 4 中的图像 3,3
    • Locate the silver strip near the top of your BlackBerry.
    • Use a plastic opening tool to pry off the edge of the silver lining.
    • Slide the tool along the length of the silver strip to completely remove it.
  5. BlackBerry 7100g Housing Replacement: 步骤 5 中的图像 1,2 BlackBerry 7100g Housing Replacement: 步骤 5 中的图像 2,2
    • Do not lose the screws. They are quite small and can easily be misplaced.
    • Locate and unscrew the four (4) screws using a T6 screwdriver.
  6. BlackBerry 7100g Housing Replacement: 步骤 6 中的图像 1,3 BlackBerry 7100g Housing Replacement: 步骤 6 中的图像 2,3 BlackBerry 7100g Housing Replacement: 步骤 6 中的图像 3,3
    • The keypad cover may fall out of the housing when prying the housing apart.
    • Tightly pinch the top of the front and back halves of the housing.
    • Carefully pry the two halves of the housing apart.
  7. BlackBerry 7100g Housing Replacement: 步骤 7 中的图像 1,1
    • You can now easily remove the "guts" of the phone from the housing.
结论
另外一个人完成了本指南。
Kellan
于03/30/10注册
277 声望
创作了3篇指南
团队
Cal Poly, Team 25-87, Amido Spring 2010 Cal Poly, Team 25-87, Amido Spring 2010 的会员
CPSU-AMIDO-S10S25G87
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 2,285
