跳转到主内容
Black and Decker WP900 Power Switch Replacement
你所需要的
  1. Black and Decker WP900 Power Switch Replacement, Power Switch: 步骤 1 中的图像 1,1
    • Using the plastic tool, detach the handle tab as shown.
    • Make sure the device is unplugged.
  2. Black and Decker WP900 Power Switch Replacement: 步骤 2 中的图像 1,1
    • Using the Philips #1 screwdriver, unscrew all of the screws. There should be 8-30mm screws to remove.
    • Be sure to keep track of where each screw was placed in the device for later reassembly.
  3. Black and Decker WP900 Power Switch Replacement: 步骤 3 中的图像 1,3 Black and Decker WP900 Power Switch Replacement: 步骤 3 中的图像 2,3 Black and Decker WP900 Power Switch Replacement: 步骤 3 中的图像 3,3
    • Remove the back panel of the external casing, leaving all internal components resting in the front panel.
    • Remove the black handle from the main external casing.
  4. Black and Decker WP900 Power Switch Replacement: 步骤 4 中的图像 1,1
    • Loosen the power cord and control panel. Using the Phillip's #1 screwdriver, remove two 22mm screws.
    • The metal bracket will detach with the two screws.
    • Using the Flathead 3/32" screwdriver, remove two 22mm screws.
  5. Black and Decker WP900 Power Switch Replacement: 步骤 5 中的图像 1,2 Black and Decker WP900 Power Switch Replacement: 步骤 5 中的图像 2,2
    • Gently pull the power cord out from the control module.
    • Remember, when reassembling the device, the black wire should be on the top
  6. Black and Decker WP900 Power Switch Replacement: 步骤 6 中的图像 1,1
    • Firmly grasping the motor, dislodge the internal components from the frontal external casing.
    • Switch and control panel will be attached to magnet body.
  7. Black and Decker WP900 Power Switch Replacement: 步骤 7 中的图像 1,1
    • Remove the switch from the wires.
    • Gently, pull and release the two wired connections.
    • The switch can now be replaced. Be sure not to damage the two connections to the control module in the process.
结论
Cameron
于02/15/16注册
231 声望
创作了2篇指南
团队
IUPUI, Team 8-8, Wilson Spring 2016 IUPUI, Team 8-8, Wilson Spring 2016 的会员
IUPUI-WILSON-S16S8G8
4 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 1,149
