跳转到主内容
Black and Decker WP900 Motor Replacement
你所需要的
  1. Black and Decker WP900 Motor Replacement, Motor: 步骤 1 中的图像 1,1
    • Using the plastic tool, detach the handle tab as shown.
    • Make sure the device is unplugged.
  2. Black and Decker WP900 Motor Replacement: 步骤 2 中的图像 1,1
    • Using the Philips #1 screwdriver, unscrew all of the screws. There should be 8-30mm screws to remove.
    • Be sure to keep track of where each screw was placed in the device for later reassembly.
  3. Black and Decker WP900 Motor Replacement: 步骤 3 中的图像 1,3 Black and Decker WP900 Motor Replacement: 步骤 3 中的图像 2,3 Black and Decker WP900 Motor Replacement: 步骤 3 中的图像 3,3
    • Remove the back panel of the external casing, leaving all internal components resting in the front panel.
    • Remove the black handle from the main external casing.
  4. Black and Decker WP900 Motor Replacement: 步骤 4 中的图像 1,1
    • Loosen the power cord and control panel. Using the Phillips #1 screwdriver, remove two 22mm screws.
    • The metal bracket will detach with the two screws.
    • Using the Flathead 3/32" screwdriver, remove two 22mm screws.
  5. Black and Decker WP900 Motor Replacement: 步骤 5 中的图像 1,2 Black and Decker WP900 Motor Replacement: 步骤 5 中的图像 2,2
    • Gently pull the power cord out from the control module.
    • Remember, when you're reassembling the device, the black wire should be on the top.
  6. Black and Decker WP900 Motor Replacement: 步骤 6 中的图像 1,1
    • Firmly grasping the motor, dislodge the internal components from the frontal external casing.
    • Switch and control panel are attached to the motor.
  7. Black and Decker WP900 Motor Replacement: 步骤 7 中的图像 1,2 Black and Decker WP900 Motor Replacement: 步骤 7 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the two 22mm screws securing the brush assembly to the motor.
  8. Black and Decker WP900 Motor Replacement: 步骤 8 中的图像 1,2 Black and Decker WP900 Motor Replacement: 步骤 8 中的图像 2,2
    • To fully remove the brush assembly from the motor, push the brushes (enclosed in the gold ribbing) outward and pull up.
  9. Black and Decker WP900 Motor Replacement: 步骤 9 中的图像 1,1
    • With a large amount of force, pull the motor up and off of the wire coil.
结论
另外一个人完成了本指南。
Stefan Wolowec
于02/15/16注册
128 声望
撰写一个指南
团队
IUPUI, Team 8-8, Wilson Spring 2016 IUPUI, Team 8-8, Wilson Spring 2016 的会员
IUPUI-WILSON-S16S8G8
4 名成员
创作了4篇指南
一条评论
Very straightforward tutotial. We are writing review of this product here https://www.helpful.reviews/en/product/4.... However we have not found many cases among owners of this product that they would need to repair motor by its replacement.
John Bazmek - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 23
总计 2,277
