跳转到主内容
Black and Decker WP900 Exterior Casing Replacement
你所需要的
  1. Black and Decker WP900 Exterior Casing Replacement, Exterior Casing: 步骤 1 中的图像 1,1
    • Using the plastic tool, detach the handle tab as shown.
    • Make sure the device is unplugged.
  2. Black and Decker WP900 Exterior Casing Replacement: 步骤 2 中的图像 1,1
    • Using the Phillips #1 screwdriver, unscrew all of the screws. There should be 8-30mm screws to remove.
    • Be sure to keep track of where each screw was placed in the device for later reassembly.
  3. Black and Decker WP900 Exterior Casing Replacement: 步骤 3 中的图像 1,3 Black and Decker WP900 Exterior Casing Replacement: 步骤 3 中的图像 2,3 Black and Decker WP900 Exterior Casing Replacement: 步骤 3 中的图像 3,3
    • Remove the back panel of the external casing, leaving all internal components resting in the front panel.
    • Remove the black handle from the main external casing.
  4. Black and Decker WP900 Exterior Casing Replacement: 步骤 4 中的图像 1,1
    • Using the Phillips #1 screwdriver, remove the two 22mm screws.
    • The metal bracket will detach with the two screws.
    • Using the Flathead 3/32" screwdriver, remove two 22mm screws.
  5. Black and Decker WP900 Exterior Casing Replacement: 步骤 5 中的图像 1,2 Black and Decker WP900 Exterior Casing Replacement: 步骤 5 中的图像 2,2
    • Gently pull the power cord out from the control module.
    • Remember, when reassembling the device, the black wire should be on the top.
  6. Black and Decker WP900 Exterior Casing Replacement: 步骤 6 中的图像 1,1
    • Firmly grasping the motor dislodge the internal components from the frontal external casing.
    • Once the motor has been removed, the external casing can now be replaced.
结论
David Hutchings
于03/28/16注册
101 声望
撰写一个指南
团队
IUPUI, Team 8-8, Wilson Spring 2016 IUPUI, Team 8-8, Wilson Spring 2016 的会员
IUPUI-WILSON-S16S8G8
4 名成员
创作了4篇指南
一条评论
Hello, this is Adam Kinnett from Group 7. You have done an excellent job on your photos as well as the descriptions and formatting.
**One of your Wiki pages on the search says "Back and Decker".
Adam Kinnett - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 878
