跳转到主内容
Black and Decker Toast R Oven Knobs Replacement
你所需要的
  1. Black and Decker Toast R Oven Knobs Replacement, Knobs: 步骤 1 中的图像 1,1
    • Make sure that the toaster is unplugged before you begin.
    • Turn the toaster upside down and remove the two Phillips #4 1 cm screws attached to the side panels.
  2. Black and Decker Toast R Oven Knobs Replacement: 步骤 2 中的图像 1,2 Black and Decker Toast R Oven Knobs Replacement: 步骤 2 中的图像 2,2
    • Pull down and out to remove side panels from the unit
    • Repeat for the other side.
  3. Black and Decker Toast R Oven Knobs Replacement: 步骤 3 中的图像 1,1
    • Remove the bottom vent.
    • This should come off fairly easy.
  4. Black and Decker Toast R Oven Knobs Replacement: 步骤 4 中的图像 1,1
    • Remove the two Phillips #4 1 cm screws that connect the bottom panel to the unit.
  5. Black and Decker Toast R Oven Knobs Replacement: 步骤 5 中的图像 1,1
    • Remove the crumb tray (bottom metal panel) from the toaster unit.
  6. Black and Decker Toast R Oven Knobs Replacement: 步骤 6 中的图像 1,1
    • Remove the aluminum strip on the bottom of the unit.
  7. Black and Decker Toast R Oven Knobs Replacement: 步骤 7 中的图像 1,1
    • Remove knobs by pulling up on them.
  8. Black and Decker Toast R Oven Knobs Replacement: 步骤 8 中的图像 1,1
    • Unhook the bottom of the display panel from the toaster unit.
    • It will be a little tough to pry off, but don't be afraid to be forceful.
  9. Black and Decker Toast R Oven Knobs Replacement: 步骤 9 中的图像 1,1
    • Begin to detach the back panel from the toaster unit and unhook the rest of the display panel.
    • This will also be a little tough to get off, but don't be afraid to be forceful.
结论
To reassemble your toaster, follow these directions in reverse.
另外一个人完成了本指南。
Jonathan
于09/18/12注册
281 声望
创作了5篇指南
团队
Cal Poly, Team 2-10, Propen Fall 2012 Cal Poly, Team 2-10, Propen Fall 2012 的会员
CPSU-PROPEN-F12S2G10
4 名成员
创作了5篇指南
一条评论
very interesting post
James Evans - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 22
总计 4,811
