跳转到主内容
Black and Decker TO1303SB Door Replacement
你所需要的
  1. Black and Decker TO1303SB Door Replacement, Top Cover: 步骤 1 中的图像 1,2 Black and Decker TO1303SB Door Replacement, Top Cover: 步骤 1 中的图像 2,2
    • Remove the six 9.5mm screws on the back panel using a #2 Phillips screwdriver.
  2. Black and Decker TO1303SB Door Replacement: 步骤 2 中的图像 1,1
    • Remove the two 13mm screws, located between the feet on the bottom of the cover, using a Torx T15 screw driver.
    • On the TO1313SB, a Security Torx T15 driver is required — the screws have a center pin that prevents use of a regular T15 driver.
  3. Black and Decker TO1303SB Door Replacement: 步骤 3 中的图像 1,1
    • Using the metal spudger, carefully pry out the rubber base on each foot to access the screws.
  4. Black and Decker TO1303SB Door Replacement: 步骤 4 中的图像 1,1
    • Remove the 11.5 mm screws using a #2 Phillips screwdriver.
  5. Black and Decker TO1303SB Door Replacement: 步骤 5 中的图像 1,2 Black and Decker TO1303SB Door Replacement: 步骤 5 中的图像 2,2
    • Remove the back cover by gently pulling the sides of the cover apart from the rest of the oven. Then, tilt the cover towards the face and pull back at an upward angle. The cover should slide right off.
  6. Black and Decker TO1303SB Door Replacement, Door Spring: 步骤 6 中的图像 1,3 Black and Decker TO1303SB Door Replacement, Door Spring: 步骤 6 中的图像 2,3 Black and Decker TO1303SB Door Replacement, Door Spring: 步骤 6 中的图像 3,3
    • With the needle nose pliers, grasp the hook of the rear spring as close as you can to the coils. Stretch the spring back and, with a twisting motion, pull the hook out of its catch.
    • It is recommended to close the door before doing this.
    • Slowly relieve the tension after pulling it out of the catch or else it may damage the spring attachment.
  7. Black and Decker TO1303SB Door Replacement: 步骤 7 中的图像 1,1
    • Pull the front hook out of the spring attachment.
    • When replacing the spring, it is recommended to start by reattaching the hook onto the rear catch, then the front spring attachment. Attaching to the front spring attachment first will cause unnecessary stress to the attachment and may cause it to deform.
  8. Black and Decker TO1303SB Door Replacement, Control Knobs: 步骤 8 中的图像 1,1
    • Using two metal spudgers, pry the top control knob directly outward.
  9. Black and Decker TO1303SB Door Replacement: 步骤 9 中的图像 1,1
    • Using the two metal spudgers, pry the middle control knob directly outward.
  10. Black and Decker TO1303SB Door Replacement: 步骤 10 中的图像 1,1
    • Using the two metal spudgers, pry the bottom control knob directly outward.
  11. Black and Decker TO1303SB Door Replacement, Door: 步骤 11 中的图像 1,2 Black and Decker TO1303SB Door Replacement, Door: 步骤 11 中的图像 2,2
    • Remove the two #2 Phillips Head x 5.5mm screws holding the timer controls to the face.
  12. Black and Decker TO1303SB Door Replacement: 步骤 12 中的图像 1,2 Black and Decker TO1303SB Door Replacement: 步骤 12 中的图像 2,2
    • On the left side, use a metal spudger to push the hinge pin in as far as you can.
  13. Black and Decker TO1303SB Door Replacement: 步骤 13 中的图像 1,2 Black and Decker TO1303SB Door Replacement: 步骤 13 中的图像 2,2
    • On the right side, pull the now extruded hinge pin out about 1/4 of an inch.
    • If necessary, use tweezers or needle- nose pliers to perform this step.
    • Removing the oven controls may make it easier to perform this step. See steps 9-11 for replacing the Heat Controls at Black and Decker TO1303SB, TO1313B Heat Controls Replacement
  14. Black and Decker TO1303SB Door Replacement: 步骤 14 中的图像 1,2 Black and Decker TO1303SB Door Replacement: 步骤 14 中的图像 2,2
    • On the left side, push out the spring attachment while pulling on the door in an upward, outward, location
    • Do not lose the rubber bushing that falls out.
    • You may need to push the spring attachment down in order to fit it through the slot in the door.
  15. Black and Decker TO1303SB Door Replacement: 步骤 15 中的图像 1,1
    • To remove the door, slightly pull the bottom left corner away from the face and slide the entire door to the left.
    • During reassembly, make sure to place the rubber bushing back on the axle.
    • When placing the new door into the toaster, guide the spring attachment back into the slot and push it up when closing the door or else it will get caught and possibly be damaged.
结论
团队
Cal Poly, Team 5-11, Maness Fall 2015 Cal Poly, Team 5-11, Maness Fall 2015 的会员
CPSU-MANESS-F15S5G11
4 名成员
创作了5篇指南
一条评论
I have the Black and Decker TROS1500 SpaceMaker Toaster Oven and the door handle fell off. Although my model is somewhat different, these images gave me the confidence to disassemble the unit and remove the door to work on the handle. I thought a rivet had broken, but it turned out that the handle attaches with screws and the screws had just come loose. I could have fixed that without disassembly, but I may not have started if I hadn’t seen this page. Kudos to you and IFIXIT!
I was not able to find any repair images or video on Google or YouTube. The SpaceMaker line is down to one model with mediocre reviews. I’m glad I was able to repair mine and save $130.
Ben Sacheri - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 41
过去 30 天: 131
总计 4,313
