跳转到主内容
Black and Decker Pivot Plus PD600 Pivot Button Disassembly
你所需要的
  1. Black and Decker Pivot Plus PD600 Pivot Button Disassembly, Black and Decker Pivot Plus PD600 Pivot Button Disassembly: 步骤 1 中的图像 1,2 Black and Decker Pivot Plus PD600 Pivot Button Disassembly, Black and Decker Pivot Plus PD600 Pivot Button Disassembly: 步骤 1 中的图像 2,2
    • Locate the pivot button screw labeled with a lock symbol.
    • Remove the screw with a Phillips #1 screwdriver.
  2. Black and Decker Pivot Plus PD600 Pivot Button Disassembly: 步骤 2 中的图像 1,2 Black and Decker Pivot Plus PD600 Pivot Button Disassembly: 步骤 2 中的图像 2,2
    • Set the screw to the side.
    • Remove both sides of the button from the screwdriver.
    • You will be left with three pieces: a black piece with a lock on the front, a circular orange piece, and a spring.
结论
Ryan Angelich
于05/13/13注册
101 声望
撰写一个指南
团队
Cal Poly, Team 4-15, Maness Spring 2013 Cal Poly, Team 4-15, Maness Spring 2013 的会员
CPSU-MANESS-S13S4G15
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 13
总计 1,141
