跳转到主内容
Black and Decker Pivot Plus PD600 Motor Replacement
你所需要的
  1. Black and Decker Pivot Plus PD600 Motor Replacement, Drill: 步骤 1 中的图像 1,3 Black and Decker Pivot Plus PD600 Motor Replacement, Drill: 步骤 1 中的图像 2,3 Black and Decker Pivot Plus PD600 Motor Replacement, Drill: 步骤 1 中的图像 3,3
    • Remove the nine 15mm Philips #1 screws
    • Remove the two 12.5mm Philips #1 screws
    • Remove the two 10mm Philips #1 screws
  2. Black and Decker Pivot Plus PD600 Motor Replacement: 步骤 2 中的图像 1,1
    • Lift one side of the drill casing off of the drill. Note that the drill casing consists of two pieces on either side of the drill.
  3. Black and Decker Pivot Plus PD600 Motor Replacement, Motor: 步骤 3 中的图像 1,1
    • After opening the the casing, locate and grab the head of the drill. Twist the motor counter-clockwise and pull to detach it from the transmission.
    • However, do not pull too hard because the motor is attached to other components of the drill by wires.
  4. Black and Decker Pivot Plus PD600 Motor Replacement: 步骤 4 中的图像 1,2 Black and Decker Pivot Plus PD600 Motor Replacement: 步骤 4 中的图像 2,2
    • After taking out the motor, you can observe two wires that are plugged in (or possibly soldered, depending on which variant you have) to the bottom of the motor. To detach the motor, unplug the wires or desolder their connections with a soldering iron as needed.
    • Mark or color code the black and red wires so you can return them to the correct position.
  5. Black and Decker Pivot Plus PD600 Motor Replacement: 步骤 5 中的图像 1,1
    • Wait for the wires and connectors to cool. Pull the wires from the motor and the motor should now be fully disconnected from the drill.
结论
4等其他人完成本指南。
团队
Cal Poly, Team 4-15, Maness Spring 2013 Cal Poly, Team 4-15, Maness Spring 2013 的会员
CPSU-MANESS-S13S4G15
5 名成员
创作了6篇指南
一条评论
If my motor try to turn is there anything I can do to fix-it? :)
Kenny Ray Carder - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 7
总计 1,309
