跳转到主内容
Black and Decker Pivot Plus PD600 LED light Replacement
你所需要的
  1. Black and Decker Pivot Plus PD600 LED light Replacement, Drill: 步骤 1 中的图像 1,3 Black and Decker Pivot Plus PD600 LED light Replacement, Drill: 步骤 1 中的图像 2,3 Black and Decker Pivot Plus PD600 LED light Replacement, Drill: 步骤 1 中的图像 3,3
    • Remove the nine 15mm Philips #1 screws
    • Remove the two 12.5mm Philips #1 screws
    • Remove the two 10mm Philips #1 screws
  2. Black and Decker Pivot Plus PD600 LED light Replacement: 步骤 2 中的图像 1,1
    • Lift one side of the drill casing off of the drill. Note that the drill casing consists of two pieces on either side of the drill.
  3. Black and Decker Pivot Plus PD600 LED light Replacement, LED light: 步骤 3 中的图像 1,1
    • In order to replace the small LED light look below the motor at the front of the drill to find a black plastic piece with two very skinny wires emanating from it.
    • The black plastic piece is the housing. The light is placed inside this black plastic housing.
  4. Black and Decker Pivot Plus PD600 LED light Replacement: 步骤 4 中的图像 1,1
    • Pull the black plastic piece up out of the slot in the drill body that it fits into.
  5. Black and Decker Pivot Plus PD600 LED light Replacement: 步骤 5 中的图像 1,1
    • The light itself can be easily removed from the black plastic piece by simply pulling it out.
    • One of the metal “legs” on the LED is longer than the other and it must be placed in the black plastic housing in the same manner it was removed or it will not work.
  6. Black and Decker Pivot Plus PD600 LED light Replacement: 步骤 6 中的图像 1,1
    • Take your new LED and slide it back into the plastic housing in the same orientation as the old LED.
结论
2等其他人完成本指南。
justin boyd
于05/13/13注册
131 声望
撰写一个指南
团队
Cal Poly, Team 4-15, Maness Spring 2013 Cal Poly, Team 4-15, Maness Spring 2013 的会员
CPSU-MANESS-S13S4G15
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 782
